Stock Wires with Pertronix Ignitor II
Old Sep 9, 2014 | 02:04 PM
Boilerz25's Avatar
I just bought the Pertronix Ignitor II to replace the points on my stock 69 442 setup and just realized they recommend not using copper core plug wires. The question is whether the wires I have fall into this category. I bought the date-coded reproduction wires offered on SuperCarsUnlimited about a month ago. I am curious if anyone has had any experience with this issue.
Sean
Old Sep 9, 2014 | 02:35 PM
No, the wires on your car currently should work fine. All your doing is installing a points replacement setup and using the same cap.
Old Sep 9, 2014 | 04:20 PM
Mark57's Avatar
I think the issue with Pertronics is not to use solid core wires. This is from the site:
"You cannot use solid core (typically copper) spark plug wires with this product. Solid core wires do not suppress electro magnetic interference (EMI) which will interfere with electronics in this product. A suppression style or spiral wound spark plug wires must be used."
Mark
Old Sep 9, 2014 | 05:29 PM
Boilerz25's Avatar
Thanks guys. I also read the stamping on the wires and they state "Supression" which is what Pertronix is recommending to avoid interference.
Sean
Old Sep 10, 2014 | 11:53 PM
enthusiast's Avatar
I am planning on installing the same parts on my 69 442. I have not done mine yet post up your install after you are done.
Old Sep 11, 2014 | 12:47 AM
johnnyjaws's Avatar
All that means is ur radio might have static in it when u play it
Old Sep 11, 2014 | 03:12 AM
Yellowstatue's Avatar
I have stainless steel GM wires on the 442 and do not have any problems with static or interference on the radio or hear any static on another vehicle's radio when within earshot.
Old Sep 11, 2014 | 06:21 AM
jaunty75's Avatar
And only if you listen to AM radio, and who listens to that anymore?
Old Sep 11, 2014 | 03:46 PM
This reminds me of a time years ago when I was sitting at a stop light and a very radical sounding '57 Chevy came from the road to the right and made a left turn in front of me. My radio went blank as it passed by, then came back on after he was gone. That was my first experience with solid core plug wires.
Old Sep 11, 2014 | 04:49 PM
TripDeuces's Avatar
"I have stainless steel GM wires on the 442 and do not have any problems with static or interference on the radio or hear any static on another vehicle's radio when within earshot."
Probably because they are spiral wound and not the solid core wire everyone here is referring too. Big difference between the two.
Old Sep 11, 2014 | 07:32 PM
Tedd Thompson's Avatar
Hay hay, I only have AM, whats the matter with AM anyway......TEdd
Old Sep 12, 2014 | 03:20 AM
I listen to AM every day. Road and traffic on 680 and oldies on 560, 740, 1150 and 1580 on the weekends in the '57. When they close the 401 both directions for thirty minutes at a time to lift beams in place for a new bridge, you want to know when to bail out and detour. A couple or three crashes every day, or some dingaling wants check out the bottom of his rig, or four wheeler, on an off or on ramp and you don't want to be there!
68442Convertible
Sep 4, 2016 04:50 AM
amphicar770
Oct 31, 2010 05:38 PM
Big Todd
Oct 16, 2010 11:38 AM
cessna195
May 15, 2010 02:35 PM
cessna195
Feb 23, 2010 07:16 AM
