Starting problem-shift linkage?
Old Sep 8, 2010 | 03:08 PM
msco123's Avatar
On my conversion from bench to bucket, I changed out the steering column.
Now I am having problems starting the car. If I hold the key engaged and roll the shift slightly around, the car will eventually start. Is there some adjustment I can make on the shift linkage or is the problem elsewhere such as a bad starter?
Old Sep 8, 2010 | 03:32 PM
bil's Avatar
bil
I would check and see if the neutral safety switch is adjusted correctly first. Standard or automatic trans?? ---bil
Old Sep 8, 2010 | 05:16 PM
Bluevista's Avatar
Registered
X2 If you're turning the steering column shift bowl and it starts.
Did you put a console in and change to a floor shift column?
If so, did you put the back linkage in to the the steering column to operate the neutral safety switch/reverse lights and lock the shifter with the steering column?
If not, never mind.
Old Sep 8, 2010 | 06:09 PM
gbodyfan's Avatar
If its just not shifting far enough into park i would say you need to adjust the linkage. i had friends switch trans in cars and they would only start if they pulled up on the shift linkage
bccsrc
Nov 29, 2011 11:08 PM
oldzy
Dec 10, 2010 02:38 PM
tarheeldoc
Jun 5, 2009 11:38 AM
Bunser
Mar 27, 2008 05:23 PM
