SR59 Battery
Old May 23, 2018 | 09:18 AM
Chris Cutty's Avatar
SR59 Battery
Supposedly these are the original style batteries used in the old cutlass. I know some people prefer to buy the topper to achieve the same look. Do you guys think this is a good buy? Would you recommend? https://www.batterycentralmall.com/Batteries/TurboStart/Script/SR59_HC.html
Old May 23, 2018 | 10:39 AM
They are getting pretty expensive. I used one on my Fury because it was a show car. On my Cutlass, which is more of a driver, I bought a Walmart battery and removed the stickers. If your not concourse showing your car, spend your money on other things.
Old May 23, 2018 | 11:28 AM
VC455's Avatar
Barely Registered
Cutlass 455s used a 71-series battery (larger physical size).
Old May 23, 2018 | 02:20 PM
The SR59 is the AGM version of the original R59 battery. Shop around. Remy sells the same AGM version of the R59 for $200. Speedway sells it for $324. Antique Auto Battery sells it for $260. Of course, be sure to add shipping costs. I've found that often the really low priced vendors have very high shipping costs and the total delivered price ends up being about the same.
Old May 23, 2018 | 05:25 PM
I checked my 71 cutlass sx which has a 455 in it and the battery tray is 10 inches not 12. Why do you think that is? Should I try to swap out to the bigger size or let it be?
Old May 23, 2018 | 07:17 PM
If it's like my car, the battery tray has rusted out and been replaced many times over the years.
Old May 24, 2018 | 05:22 AM
x2
Sam's Club or Costco are the best source for batteries and tires. If you aren't showing your Olds then just get a store bought replacement.
Old May 24, 2018 | 08:39 AM
RetroRanger's Avatar
72 Olds CS
I just replaced my battery in my cutlass. I got an AGM battery at advance auto 3 year free replacement, about $180.
Old May 24, 2018 | 01:46 PM
Just to be clear, I'm ASSUMING the OP wants a correct-appearing R59 battery. If not, then yes, I've had excellent results with WalMart, AutoZone, NAPA, etc.
Old May 24, 2018 | 04:57 PM
66-3X2 442's Avatar
The R-69 is the correct battery for late 66-67 442's. Nobody has made the R-69 as of now. The only difference between the 59 & 69 is,the 69 is 1" taller.
Old Apr 29, 2020 | 07:37 AM
Burd's Avatar
Old Nov 29, 2020 | 07:24 AM
Burd's Avatar
Old Sep 15, 2022 | 05:48 PM
Motleyfan's Avatar
Burd... do you sill have any of the toppers available. I have a 77 Trans Am.
Thanks,
Nick
Old Sep 15, 2022 | 06:12 PM
Thanks,
Nick
I’m sure he does but I doubt he’ll see your post, send him a private message.
Old Sep 17, 2022 | 06:16 AM
Burd's Avatar
Old Feb 19, 2025 | 03:41 PM
Burd's Avatar
Old Nov 1, 2025 | 03:05 PM
Burd's Avatar
Thanks,
Nick
yes, get ahold of me. All 5 are in stock.
Old Yesterday | 07:20 AM
Burd's Avatar
Spring Topper sale, just for Classic Olds, no where else, take 10$ off any of the 5 topper avail, sale hood thru April 15. If PayPal is used, F/F must be used. Thanks.
FStanley
Feb 28, 2023 02:48 PM
chip-powell
Oct 22, 2015 04:56 PM
costpenn
May 18, 2015 08:10 PM
auto_editor
Mar 26, 2015 09:20 AM
Pfiffle
Mar 3, 2008 08:01 AM
