Rally Pak Issues
Rally Pak Issues
Installed a rebuilt Rally Pak setup in my 70 442. I followed, At least I thought I did, The great directions from GAOldsman but still wound up with some issues
Any guidance on where I should start looking would be appreciated.
- Tach works but clock doesn't
- None of the gauges work correctly
- All lights work.
- When I pulled the gauge cluster back out of the dash it seemed really hot. At least hotter than I would have expected it to be.
I have restored many sets of rally packs for customers. It is very common for the clock not to work. GM really did not mean for this stuff to last 45 years. A quartz kit replacement for the clock would most likely fix that issue.
I don't know what all you have done so this question may sound dumb. Do you have the correct sending units for the rally pack installed on your engine? I'm not sure about the getting hot issue? Sounds like a good idea to install the other rally pack and see what happens.
