rally pac conversion
Old Jul 8, 2007 | 12:27 AM
mr-tom's Avatar
Unhappy rally pac conversion
got all the wires switched over on the oil,fuel,temp pretty sure when i pulled the gages out of the parts car it was grounded so i hook up a ground wire right a way the gages move right to to the top i know the car on empty so something im doing is wrong too to ground off fuel gage reads right might just have a good enought ground the tach wasnt in the parts car so i dont know what terminal is for the power and tach feed
thanks for the help
tom
Old Jul 12, 2007 | 08:27 PM
perro's Avatar
unsure what year youre dealing with, but i can tell you this to be true on a 1968 - if it has a rally pac im assuming its a 68-72 and this should still apply, but unless its 1968, i cant promise it will.
im unsure by reading what you are trying to accomplish with the gas part of your question
the gauges on a 1968 are grounded by thin little metal straps on the dash. The 2 screws that hold each gauge in the dash pass through the metal straps to ground that gauge out. Between each gauge is a grounding jumper wire that runs from gauge to gauge. The fuel gauge should have a ground strap and the tach should have a ground strap, but between the tach to the speedo, and the speedo to the cluster you will have jumper wires that bond each gauge to each other (at least mine did). if all 3 gauges arent bonded to each other and to the ground straps, make it so.
at your gas tank you will have a ground wire that grounds the tank to the chassis sheet metal. crawl under your gas tank and just in front of the gas tank on the drivers side you should see a ground wire running up to a screw that screws into the sheet metal - make certain thats a clean good ground.
grounding the brown fuel gauge wire (not the wire that runs to your tank, but the one that runs through your intermediate wire harness to the dash) should give you a 100% empty reading on the gas gauge - if you are curious about testing the wire that runs from the tank to the gauge, pop your trunk and find the brown clip that goes through the trunk and down to the gas tank behind the liscense plate. Unplug it and ground it out to bare metal somewhere (ground the wire that runs to your dash, not the one that goes to the tank). Turn your key on and the gauge should move to the 100% empty position. If it moves to the 100% empty position then the wire running from the gauge to the trunk is good, and the fuel gauge is good, your problem is either in the wire from the trunk to the sending unit, or the sending unit. If it doesnt read 100% empty then either your wire from the trunk is bad or hooked up wrong, or your fuel gauge is bad.
the sending unit is a Rheostat - when the float moves it gives you different levels of resistance which is what your fuel gauge reads. if you pull the sending unit out of the gas tank and hook up an OHM meter from the 2 terminals, when its full it should read close to 90 OHMS of resistance on the Ohm meter. When the float is moved to the empty position it should read close to zero OHMs (the equivalent of grounding out the wire in the trunk or zero ohms of resistance)
of course a half of a tank should read 45 ohms resistance on a 90 ohm sender
that should troubleshoot your fuel gauge
your tach hookup - you should have 3 large binding posts that form a triangle. There should be black insulators on the top post, and there should be 2 binding posts with red insulators on it.
Looking at the gauge from the back, the red binding post on the left should be your clock hookup
the red binding post on the right should be the brown wire that has the 2 amp fuse holder on it and the bare wire protective covering over it and this runs to the negative side of your coil.
if memory serves me correctly the top center binding post hooks up to your dash lights - directly above that will be a sticker - peel the sticker away and the small screw inside of the case is how you adjust the RPM reading of the tach
hope this helps
Mike
Old Jul 12, 2007 | 08:42 PM
perro's Avatar
forgot to also mention
if your car didnt have a rally pac in it to begin with, you need to remove the green ground wire at the ignition switch packard housing that hooks up to the back of the ignition switch in the dash.
this ground wire will cause gauges to peg when you turn on the key if your car didnt originally have rally pac gauges
if you remove the ignition switch from the dash and look at the back of it, it will have a green wire and on the switch itself should be the letters "GND" for ground. Pop that green wire out of the packard housing and then reinstall everything as it was before.
Old Jul 20, 2007 | 09:50 PM
Omicron's Avatar
Site Admin & Motorhead
Check out post #5 in this thread. Supermod Texasred provided wiring diagrams that may well help ya. Good luck, and keep us posted on this... I'm thinking of doing the same thing.
Old Jul 20, 2007 | 11:15 PM
mr-tom's Avatar
done the job got every thing working exept oil preesure guage is frozen only problem i have to figure out now is i have no cluster lights no power down to the fuse also no turn signal or hazard light any one have an idea on those problems
Del70
Oct 2, 2025 11:32 AM
Lady72nRob71
Oct 6, 2019 07:24 AM
nelsontj
Sep 15, 2012 12:32 PM
RAMBOW
Mar 23, 2009 02:05 PM
