Question about 72 Supreme map light...
Old October 28th, 2018, 07:39 PM
72455's Avatar
Doing some research...does the map light above the radio only work when the headlight switch is on, when the key is on, or does it have it's own circuit?
Thanks,
Dave
72455 is online now
Old October 28th, 2018, 08:03 PM
It has its own circuit that is always hot. Back in the early 90s I inadvertently turned mine on after cleaning the car (couldn't tell it was on in the bright daylight) and the light got so hot that it cracked the rearview mirror glass.
Fun71 is online now
Old October 28th, 2018, 08:06 PM
72455's Avatar
Oops...I should have specified...the map light above the radio😀
72455 is online now
Old October 28th, 2018, 08:11 PM
Oh. Just like the mirror map light, the dash map light has its own supply / switch so it can be turned on at any time.
Fun71 is online now
Old October 28th, 2018, 08:15 PM
72455's Avatar
Copy that and thanks. Guess I'll start with the bulb and go from there.
72455 is online now
Old October 31st, 2018, 06:40 PM
Rosie39j's Avatar
Sme problem. Anybody know of an led option so when I leave it on I don’t run down battery?
Rosie39j is offline
Old November 1st, 2018, 08:36 AM
oddball's Avatar
Over at SupreBrightLEDs.com it's either RL4410-WWHP9 or 4410-WW8. I think the first one. The problem is hanging by the wires causes the LEDs to point off to the side so you don't get much light. I modified the housing to angle it closer to straight down. And the mounting is a little finicky for that type of bulb.
oddball is offline
therobski
August 5th, 2018 11:10 AM
scott_442
June 13th, 2012 07:21 AM
69'442
December 17th, 2011 07:58 PM
68ragtop
December 16th, 2010 05:37 AM
TRW
August 29th, 2010 05:20 PM
Quick Reply: Question about 72 Supreme map light...
