"Proper" way to add circuits? Vintage Air in 68 Cutlass
Hello,
What is the "best practice" way to add circuits for non-stock accessories? I am installing a vintage air unit in my 68 Cutlass and need a source of switched power. If I was younger I probably would have jabbed a spade terminal in between the fuse and fuse holder.
I've seen aftermarket "add on" fuse blocks that give 5+ circuits, but these will still need something to trigger a relay to turn power on when the key is on.
I'm looking for advice on the best way to get this power, and if an addon fuse block is the best way, what are the best places to mount it? I'm trying to keep the non-stock aspects of my car as hidden as reasonably possible.
Thanks in advance.
Thanks in advance.
How much current and how many circuits? The factory fuse box has terminals for IGN (powered with key in RUN), ACC (powered with key in RUN and ACCY), and BAT (powered all the time). These max out at about 20-25 amps. If you need more, use a relay with a separate fuse or breaker wired directly to the junction post on the horn relay and controlled by a wire to the IGN or ACC terminal on the fuse box. This is how the factory wired high current accessories like power windows or seats.
Wow, now I'm mad at myself. I just realized that the old HVAC controls had a brown power wire that gives me a convenient, non-modifying source of power that is already right where I need it. Now if only I had made that realization before posting and letting everybody else know that I missed it
Note the wiring diagram above. The brown wire feeds the Vintage Air ECU. There's a separate wire out of the ECU that triggers the relay as needed. That's similar to how the high speed blower relay works on the factory A/C.
