POS/NEG Battery Cable Gauge?
Hi.
Making my own battery cables and needed to know what recommended size would be. A company sent me some 4 AWG wire but it seems smaller than what’s needed. It’s a stock size externally regulated alternator with no power doors, windows or seats so there isn’t much draw other than necessary components. I would have thought a thicker gauge such as 1/0, 2/0, etc would be needed but even in specs on various cable manufacturing sites, it lists 4 gauge as the size. Thoughts?
When it comes to battery cables, overkill is good. What’s the point of have a battery with 800cca if most of the current is used heating up undersized cables?
Be careful of cheap cables. To keep costs down, there are some cables advertised as a certain size, but with thicker insulation and less copper wire.
I would use what’re gauge wire the factory used, maybe one size larger.
The previous of my car had cranking issues. He replaced the starter with an o.e. reman and ran 1/0 cables. I installed a 800 CCA battery after the one he installed failed. Mine cranks very fast!
Pat
Pat
