POS/NEG Battery Cable Gauge?
Old Feb 13, 2020 | 04:32 PM
tgilligan's Avatar
Hi.
Making my own battery cables and needed to know what recommended size would be. A company sent me some 4 AWG wire but it seems smaller than what’s needed. It’s a stock size externally regulated alternator with no power doors, windows or seats so there isn’t much draw other than necessary components. I would have thought a thicker gauge such as 1/0, 2/0, etc would be needed but even in specs on various cable manufacturing sites, it lists 4 gauge as the size. Thoughts?
Old Feb 13, 2020 | 05:58 PM
4ga is good for 200A on a 15 foot run. It should be fine for your car.
Old Feb 13, 2020 | 08:08 PM
When it comes to battery cables, overkill is good. What’s the point of have a battery with 800cca if most of the current is used heating up undersized cables?
Be careful of cheap cables. To keep costs down, there are some cables advertised as a certain size, but with thicker insulation and less copper wire.
I would use what’re gauge wire the factory used, maybe one size larger.
Old Feb 14, 2020 | 02:53 AM
1970cs's Avatar
Lansing built
The previous of my car had cranking issues. He replaced the starter with an o.e. reman and ran 1/0 cables. I installed a 800 CCA battery after the one he installed failed. Mine cranks very fast!
Pat
Old Feb 14, 2020 | 10:13 AM
Electrons prefer the path of least resistance.
Old Feb 14, 2020 | 04:29 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Many, many DC negative ground system problems can be attributed to bad connections. Clean all ground and positive connections. A 10 year old vehicle can easily suffer from crap grounds.
Oldssupreme
Aug 30, 2019 06:17 AM
jimvbills
Aug 21, 2016 10:12 AM
starfire
Mar 16, 2013 07:13 PM
1968Cutlassfallbrook
Aug 26, 2011 07:25 PM
BosMobile
Aug 13, 2011 12:58 PM
