Pertronix
Old May 21, 2011 | 12:51 PM
Pertronix
Does the distributor have to come out when installing the Pertronix Ignitor II? I know with the original version that it did, but cannot remember if it has to on the Ignitor II, or do I need the Ignitor III to avoid that hassle?
Old May 21, 2011 | 02:59 PM
redoldsman's Avatar
Proud Viet Nam Veteran
As you mentioned, the original version did not require removal. I can't imagine the others are any different. Try checking their website. Pertroniz makes great stuff.
Old May 21, 2011 | 03:55 PM
jensenracing77's Avatar
i just installed an Ignitor II on the original distributor for my Rallye 350. my distributor was all ready out but when i went by the directions i had to remove the bottom gear to install washers to take up some end play. i don't know how much the end play is an issue but you would have to take it out to put these washers in if you have to much end play.
7244too
Sep 3, 2010 11:35 PM
cessna195
May 15, 2010 02:35 PM
cessna195
Feb 23, 2010 07:16 AM
BerBer5985
Jun 21, 2009 01:26 AM
Chuck C
Apr 29, 2004 02:12 PM
