One after the other
One after the other
Okay, i got the brake lights working but now my turn signals in the front light up when i step on the brakes, there are no turn signals front or back of the car everything els works.. Any clues as to what going on here?
You need to be EXTREMELY specific when describing problems like this one.
We need to know exactly which filament of which light bulb is on at exactly what time,
ie: brake pedal up, brake pedal depressed, signals switch Left, Center, and Right, 4-way switch On and Off, Headlight switch On, Park, and Off.
If we have excluded incorrectly connected wires (which we haven't), then the most likely culprit is the signal light switch.
Thank you tho, i appreciate the response
I guess I should explain:
Without the Hazard flasher in the fuse block the brake switch applies power to all of the running lights front and back. With the flasher in, it only applies power to the rear. Without the Hazard flasher the turn signal flasher will not work properly, that is why you don't have turn signals.
Don't ask me the specifics, I'm not an electrician. Just encountered this a long time ago and again a few weeks ago when my buddy's '68 Camaro had the exact same problem. I looked at the fuse panel, no flasher. Got on for $7 and plugged it in. All of a sudden, all the lights worked normally.
Be sure to report back so the next guy gets the answer easily...and so I know if my advice helped or not.
Okay guys, 1 am cali time and im dancing around the garage! Heres what happened.. My hazzard switch is a bit ghetto, someone broke it off flush to the coloum. To tell you the truth i had no idea what it was but it was pushed in and jammed so the hazzards were on the whole time! Once i unjammed it to the off position everything started working fine! Signals brake lights and all! My hazzards for some reason dont flash, perhaps the busted up switch is to blame. Either way i can live with that..
Thanks guys! It was right under my nose the whole time!
Either way id say this case is closed
The hazard switch and the signal light switch are the same thing.
It's one unit. All connected.
It sounds like you need a new one. They're about $20 at your local auto parts store.
Thanks for the replies!
Biggest problem here was you bought a car with a butchered electrical system, had to replace the harness, and then could not be sure whether each new problem was caused by your wiring, or had already existed before you touched it.
You're doing a great job getting it together, though.
My one recommendation would be that you get a copy of your Chassis Service Manual (or download it for free from WildAboutCars) and thumb through the chapter that's related to anything you're about to do before you do it - that way, you'll have a background idea of how everything works ahead of time, and you'll be able to recognize problems faster than if you've got to sit down and figure it out from scratch.
Just got on wild about cars and man! What a site!
Arrowstorm
Suspension & Handling
25
Jul 29, 2015 05:52 AM
2blu442
Nov 23, 2012 06:45 PM
