External regulator acting up only hot
I bought a new Delco regulator about 4 years ago and haven't looked back. It is the 2 coil type. The only issue I have is if I try to have a short stop on a trip. The engine compartment heats up and then the field will not contact and set up charging. It stays that way until I stop, cool off and then restart.
I know the Wells VR715 is the best bet but does anyone know why this happens? Is there a little adjustment I'm missing that could help keep this hot start from not charging my battery?
So I got some information that the field pull-in relay contacts should be 0.030in gap. I took mine apart and hte gap was 0.060 in or a little greater. I made the change to what the "spec" was as conveyed and have not had time to go for a drive. Will probably go this weekend to see if it has made a difference.
Interesting. Hope that solves your problem. Sounds like you have somewhere around a 70-72 W30? There is a great write up and pictorial in the CSM (1972) on page 12-50 and 12-51.
Or save your money and get a late model high output alternator from you local Pull-A-Part. Its a simple swap, much more reliable and better charging system performance than the 40 plus year system.
Was 0.030in the correct number then?
With .030 are you thinking maybe of the points adjustment?
