70 442 external regulator
I have An external regulator on my 70 442 455 4 speed. Seems that it should have internal being a 442, not a cutlass. 34487 vin, 455 sequence match, m21 match and build sheet.
Frame # matches sequence .
I realize all can be faked. Non w-30, a/c.
Production date was October 69.
Any enlightenment on this?
from what I have learned yes it should have been an internally regulated open-faced alternator - can't remember if AC necessitated the 63 amp or if it could have been a 37 amp. I think the 71s had both. What stampings are on the alternator? That should tell you if it was original or not.
From the 1970 Olds Chassis Service Manual
For whatever it may be worth, the service manual says both versions were used. Page 12-12 has these applications:
37 amp. - A body (V-8 or L-6) non A/C
42 amp. - B, C, and E body non A/C
55 amp. - All cars with A/C
60 amp. - K81 (police option)
63 amp - C-49 (electric rear window defogger)
Page 12-25 says: "The Delcotron generator used on all 442 models has a transistorized regulator that is mounted inside the Delcotron." I don't have the designated parts book for 1970.
Ozzie - ???? - "both versions used"???
ALL 442's, in 1970, got the internally regulated alternator according to what you posted.
Were you talking about internal vs. external or 37A vs. 55A?
I was wondering more about the reason why an "authentic" (so far as I know) 442 would have an external regulator with factory appearing harness instead of the internal that resto books call for?
Probably because someone swapped it I'm sure. They went back to external regulated alternators in 71 then I think in 73 or 74 all GMs got internal regulated again. I have seen a lot of 70s set up the way yours is. So many of these cars look "authentic" but just think, they are 43 - 44 years old. Who knows what happened to them within the first few years.
i would start with chking the harness from the regulater on the firewall forward to the engine harness on the rh fender . If the wire from there does not go into/ under the old 43 yr olds black tape within 12 inches or so of the harness, it may have been added/ spliced into an oem internal reg harness. Furthermore, this could tell you if the orig alt was replace. Very unlikely they replaced the harness also ... is what i am getting at.
Clarification?
ardvark 1
February 23rd, 2015 06:56 AM
