Oil/ Temp sending units
Hello,
When swap the connecting wire (Temp) going to the Oil or Temp it works on either one - correct? Depending on which sending unit I put it on that gauge works. It's the other wire (Oil) no matter which sending unit I put it on, neither work. I assume I have to run a knew wire from the Oil Sending Unit to inside the car.
Any other suggestions?
yalikeme
September 4th, 2015 12:25 PM
