Oil/ Temp sending units
Old May 2, 2021 | 03:23 PM
wherlehy's Avatar
Hello,
When swap the connecting wire (Temp) going to the Oil or Temp it works on either one - correct? Depending on which sending unit I put it on that gauge works. It's the other wire (Oil) no matter which sending unit I put it on, neither work. I assume I have to run a knew wire from the Oil Sending Unit to inside the car.
Any other suggestions?
Old May 2, 2021 | 04:58 PM
The oil and temp sensors work the same, the resistance value are different. Oil is a blue wire, green is for the temp.
69 Hurst
Apr 29, 2021 12:08 PM
yalikeme
Sep 4, 2015 12:25 PM
24bing
Sep 26, 2012 07:22 PM
MN71W30
May 25, 2009 04:07 AM
boese1978
Jan 22, 2008 11:56 AM
