Oil Pressure Gauge/67 442
Would anyone know why an oil pressure gauge would read at mid-range with the car not running? I am considering replacing the oil pressure/sending unit however I am wondering if it may be the gauge itself. It climbs to high after the car is started and running, indicating that it is functional, however it only returns to mid-range after I turn the car off.
Thanks Octania, I had considered that, yet wasn't sure. I only assumed it would/should go to zero. Nevertheless I now know that my oil pressure is higher than normal based on the gauge reading...although I also questioned whether stored energy within the oil pressure /sending unit would normally set the gauge to zero, when it isn't energized.....
The gauge has no real neutral position in the key off position, it just stops. With the key on and engine off it should read 0 off the sender. With the key on and the engine on it should read what the oil pressure sender is calibrated to. Since these gauges are not very accurate, if it reads anything warmed in idle its a good thing. If you want an accurate measurement I suggest an aftermarket mechanical gauge.
Thanks to all, I have yet to get a mechanical gauge to get an accurate measurement, however I did replace the pressure switch itself to see if it made a difference.... and yes it did. The gauge now reads at 0 with the key on and engine off (as stated above), it pegs slightly downward with key and engine off past zero and reads slightly pass mid-range while running.
Thanks again everyone for your input. Issue resolved
Del70
August 23rd, 2017 03:59 AM
Del70
September 11th, 2012 06:45 AM
