No gauge or interior lights
Old Mar 27, 2016 | 10:02 AM
dynamicman66's Avatar
Question No gauge or interior lights
Working on my 86 olds cutlass I checked the fuse and pulled the gauge cluster out and checked my bulbs and connections my warning lights work and all my gauges are working now. But my gauge or interior lights don't , could it be my dimmer switch
Old Mar 31, 2016 | 07:05 PM
cjsdad's Avatar
If the question is about the car in your signature, there are a couple extra questions that need answering as well. Has the factory radio/stereo been replaced? If it has, you need to make sure the grey wire was not used for, or connected to, a ground source. The grey wire is the dimmer lead for the factory radio and if it is grounded it will pop the dimmer fuse. Also check the cig lighter to make sure it is not loosening up. The **** and heating element screw together and if they loosen up the metal heating element will short out the socket and pop the lighter fuse which powers the parking light circuit if I remember correctly. That one is a little foggy now days. Another thing to check is the smoothness of the dimmer rheostat in the switch. It is a metal spring inside the switch and if it has rusted it can cause the dash lights to not work.
Old Apr 1, 2016 | 04:26 AM
Thanks cjsdad, Yes it is the car in the pic, and yes they put a other radio and hacked the factory plug off witch ill fix but all the wires there back are good, Ill have to check my lighter have not checked that yet.
Old Apr 1, 2016 | 06:17 AM
cjsdad's Avatar
The '80s stereo craze was brutal on cars of that era. I know, I was a stereo installer for 15 years starting in '80 and finished up about 95 or so. It was fun, but the stereo fad phased out and I had to get a real career.
JPMDaddy
Jan 31, 2020 04:01 AM
Markwz11
Apr 4, 2014 02:29 PM
trez
Mar 23, 2011 12:20 PM
clinton70
Feb 7, 2010 03:48 PM
silverriff
Feb 13, 2008 03:59 PM
