* No Brakes Lights Please Help...
Old Jun 11, 2006 | 03:58 PM
Pete77's Avatar
I am currently working on my 1972 Cutlass trying to do everything before I get it on the road. I have no brakes lights. I changed the stop light switch and still nothing. My lights work regularly just do not flash when I apply the brakes. Any ideas would be great I don't want to get rearended. thanks alot
Old Jun 11, 2006 | 04:05 PM
texasred's Avatar
Tom Servo's Stunt Double
Fuse?
Do the tail ligts work when the lights are on?
C.J.
Old Jun 11, 2006 | 04:23 PM
Pete77's Avatar
all lights work, but i have no brakes lights, They do not brighten up when I apply the brake. same with the lights off. I did a search on the net and came across some stuff for old GM's and people are suggesting the turn signal switch? Not sure though.
Old Jun 12, 2006 | 03:27 AM
texasred's Avatar
turn signals don't work either?
Old Jun 12, 2006 | 07:22 AM
Pete77's Avatar
no they do work but from what i have read the brake lights work through the turn signal switch and the turn signals can work and the brake lights dont.
Old Jun 12, 2006 | 06:23 PM
texasred's Avatar
You are correct, but it's a long shot. A few more questions...
Do your front turn signals work?
Do your 4-way flashers work?
Does your "key left in the ignition" buzzer and horn work?
C.J.
Old Jun 13, 2006 | 08:33 PM
Surfrat67's Avatar
Im having the same problem. Havent tried to fix it yet as I just dropped my motor in and its on the list. This should help I hope....
Old Jun 14, 2006 | 03:20 PM
Pete77's Avatar
yes sir all turn signals, flashers and annoying buzzer work. So what do you think? It may be the turn signal? thanks again for all the help
Old Jun 14, 2006 | 07:07 PM
texasred's Avatar
Last stop...check for voltage at the stop lamp switch (orange wire).
If it's not that...I'm afraid I'd start looking at that turn signal switch.
Get a Chassis Shop Manual (forget Chiltons and Haynes) on ebay. It'll pay for itself!
C.J.
cecilsclassics
Apr 17, 2015 09:56 AM
aquabird
Oct 2, 2013 10:34 PM
tds
May 7, 2013 10:18 AM
Pete77
Feb 15, 2007 02:07 AM
drtdobber
Feb 14, 2007 01:16 PM
