Need suggestions to fix buzzing sound
Old Nov 13, 2020 | 08:22 AM
724drcutlass's Avatar
I humbly need help! Buzzing noise seems to be coming from behind cigarette lighter in wires? 72 cutlass supreme. I've disconnected radio. Should I try pulling fuses to find it. I'm an old rookie 😁
Old Nov 13, 2020 | 12:18 PM
Where is the horn relay located on a '72? It has an ignition key buzzer built into the relay assembly. Seems I recall someone posting that on the '72 it is on the center of the firewall, which would be about where you say the noise is.
Also, the mechanical voltage regulator is on the firewall in that general area, and sometimes they make a buzzing noise.
edit:
I found this picture of the firewall on a 1972 Cutlass and it shows the horn relay is adjacent to the voltage regulator:
https://classicoldsmobile.com/forums...pdates-132394/
Old Nov 13, 2020 | 12:35 PM
Thanks, I'll look into that. I've got the clock out and I installed some led 194 lights in my gauges. So maybe leds causing it 👍
AJFink
Feb 13, 2019 02:28 PM
dddddyang
Apr 5, 2017 06:44 PM
Tony72Cutlass'S'
Apr 18, 2012 12:39 PM
fmbjogger
Oct 23, 2010 09:05 AM
freebird72
Oct 5, 2009 07:06 PM
