Battery recommendation
Old May 24, 2019 | 08:04 PM
al1950's Avatar
could any one recommend a 6 V battery, good quality , for my 50 88 303.
Old May 24, 2019 | 09:36 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If I remember correctly that is one of those rectangular batteries with the metal cover over it. I don't know if Walmart can get it but they have some of the best batteries around and their prices are good. Interstate might have one. It is not a common item.
Old May 25, 2019 | 06:31 AM
66-3X2 442's Avatar
I think an 8 volt will work in your car. If so,that might help.
Old May 25, 2019 | 07:02 AM
redoldsman's Avatar
An 8 volt will work but I think you will need to adjust the voltage regulator since the system is set for 6 volts.
Old May 25, 2019 | 11:23 AM
66-3X2 442's Avatar
Wasn't sure of the process but I remember using 8 volt batteries in the 6 volt cars without blowing bulbs and fuses.
Old Nov 13, 2020 | 10:44 PM
Killian_Mörder's Avatar
For those who want an original-looking battery with modern high-output innards, a factory in Germany will copy your original tar-top. It won't be cheap, though. I don't know if they'll copy the caps, if necessary. You could probably clone those in a 3-D printer, just in case:
http://www.suppliersof.com/storage-b...ng/de/80378231
Akkuwerk Sehma Produktions Gmbh
in Sehmatal, Sachsen
373366351Storage Batteries, Nsk
Karlsbader Strabe 102
Sehmatal, Sachsen, Germany
09465
The rest of the article, if anyone cares to type it into a translator:
cfair
Sep 30, 2019 10:37 AM
pdsap
Mar 8, 2017 04:18 PM
Rocketowner
Jul 1, 2015 07:16 AM
76olds
Mar 3, 2014 03:31 AM
Wyze
Dec 14, 2011 07:30 PM
