Need help with 1957 radio
Old Sep 17, 2020 | 01:19 PM
Renegade34's Avatar
I’m working on a 1957 Olds Super 88 and need some help. The model # of the radio is 989100.
Are these speaker wires? (The twisted ones).
1. Looking at the back of the radio there is a yellow wire on the left. Where does it connect to?
2. Looking at the back there is a greyish wire on the right side. Where does it connect to?
3. It has a couple of what looks like speaker leads connected to the top. Do they hook up to the + and - of the speaker like a modern one? Or is it common grounded? He took a speaker out of a newer vehicle but has never had it hooked up.
Old Sep 18, 2020 | 08:07 AM
4R5's Avatar
4R5
I don't have any Delco manuals back that far but my guess is the yellow wire is power, the gray connects to the instrument panel lights (so the radio dial lights up when the dash lights light up) and the 2 twisted wires are the speaker. Do not ground the either terminal of the speaker. Also, it looks like its missing the vibrator (that open socket). Hope this helps.
Old Sep 18, 2020 | 08:19 AM
Tedd Thompson's Avatar
I believe I have a 57 radio some where in my junk. It would be for sale if I find it. I have no idea if it will work but looks to be in good shape if I'm remembering correctly.... Tedd
Old Sep 18, 2020 | 08:28 AM
Renegade34's Avatar
Thanks for the reply. What the heck is the “vibrator” for? Will it work without it?
Old Sep 18, 2020 | 09:44 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Will not work without a vibrator. I don't know exactly what it does but it does not make the radio vibrate. It is a key part of the radio.
Old Sep 18, 2020 | 09:56 AM
Renegade34's Avatar
Thanks for the help!
Old Sep 18, 2020 | 10:21 AM
Yellowstatue's Avatar
The vibrator is available as an electronic device which warms up the tubes much more quickly than the previous original item.
Old Sep 18, 2020 | 10:38 AM
Renegade34's Avatar
If you find it I’d definitely be interested in buying it. Please let me know if you find it. Thanks.
Old Sep 19, 2020 | 06:42 AM
4R5's Avatar
4R5
The vibrator was used to convert the 6 or 12 Volts DC to AC which then a transformer was used to develop a higher voltage AC. The tubes in these radios needed a few hundred volts to operate. They are still available and there are electronic version still available as well.
Billyaxe
Apr 5, 2023 07:15 PM
Seth Anderson
Jun 8, 2016 09:57 PM
atomic13
Oct 18, 2011 08:03 PM
Oldwolf
Jan 17, 2009 03:48 PM
TIREGUY
Dec 16, 2006 04:10 PM
