My Seat Will not work old Custom Cruser 86 wagion
Old July 5th, 2008, 12:39 PM
Demonsmasher
jackmanola's Avatar
Smile My Seat Will not work old Custom Cruser 86 wagion
How can i adjust it without the electric switch
jackmanola is offline
Old July 5th, 2008, 06:16 PM
Past Administrator
Oldsguy's Avatar
You have to run a plus wire from the battery to the orange wire on the motor receptacle. I think it is orange. It would be best if you got yourself a service manual which would give you the wiring diagram that shows the wire colors. An alternate way would be to disengage the transmission shaft and move it manually.
Oldsguy is offline
Old July 6th, 2008, 07:22 AM
It depends on which seat you have. My 86 uses a single motor with three clutches for fwd/back, front up/down, and rear up/down. The motor leads are reversed in the switch (power and ground) to run the motor fwd or backward. The clutches are either engaged or disengaged. To move the seat you must simultaneously power the motor and engage the correct clutch.
There is also a version of the power seat that uses three independent reversible motors. In that case, you simply need to power the correct motor.
Starting in 1986, GM cheaped out and removed the relays, instead running the high motor current directly through the switch. This causes the switch contacts to burn out. It is possible to disassemble the switch and file the contacts, but it is not for the faint of heart. The inside of the switch uses a series of rockers and contacts that require watchmaker skill to adjust properly. I am not aware of any repro switches being sold.
joe_padavano is offline
75hurstoldsW-30
October 5th, 2019 12:03 AM
smkn600ctd
December 29th, 2014 05:38 PM
White Spyder
May 27th, 2012 10:38 AM
DAN76
September 24th, 2009 08:35 PM
lshlsh2
April 19th, 2009 05:12 AM
Quick Reply: My Seat Will not work old Custom Cruser 86 wagion
