Installing new battery cables
Old Jul 3, 2010 | 10:57 PM
georgiaboy697's Avatar
Ok so ive been haveing issues with my 1970 cutlass starting sometimes it does sometimes it doesnt I have come to the conclusion that it is my battery cables due to the fact that they are in not so good condition slightly corroded as well as fraying at the ends. I have bought the new cables and replaced the negative side that connects to the front of the engine my question is is it possible for me to change the positive side without removing the block becuase i know it goes to the starter and I can see the end of it but ive never tried to change that cable before i will post pictures in the morning if that would help i do have access to a lift but would rather not tow it to my shop lol
Old Jul 4, 2010 | 02:23 AM
oldbill's Avatar
Be sure and disconnect the negative cable (ground) before messing with the positive cable! Then after the positive is completely installed, hook up the negative again. With the car on jack stands you should be able to find the starter end of the positive cable. You may need a 9/16" wobble socket on an extension to reach the nut and disconnect it, there will probably be some brackets or connectors along the positive cable that also have to be undone to remove it. These along with any protective sleeve material should be replaced to keep the new cable from making contact with the exhaust, melting the insulation and causing a short.
Old Jul 4, 2010 | 08:16 AM
I've never been able to access the battery cable terminal on the starter of an Olds motor without dropping the starter first. Note that the Delco starter weighs about a thousand pounds - or, at least it seems that way when you're trying to hold it up with one hand and get the bolts started!
Old Jul 4, 2010 | 08:51 AM
BILL DEMMER's Avatar
Just the facts...
jack stand
bill
Old Jul 4, 2010 | 12:47 PM
The Stickman's Avatar
Truer words have been spoken.
Old Jul 4, 2010 | 01:15 PM
well I sucked it up jerry-riged the battery and drove the car to where my lift is i will just lift it up and change the cables tommorow haha and yeah i know about the starter thats why i didnt want to take it off
Old Jul 4, 2010 | 03:45 PM
jaunty75's Avatar
You mean truer words have never been spoken.
Old Jul 5, 2010 | 07:43 AM
I don't know, maybe Stick meant to say that...
Old Jul 5, 2010 | 07:48 AM
jaunty75's Avatar
Hadn't though of that!
Old Jul 5, 2010 | 08:32 AM
Blk71SX's Avatar
no way to change the cable without removing the starter. the starter can be removed without removing the trans dust shield. be aware of any starter shims that are present.
Old Jul 5, 2010 | 08:55 AM
lshlsh2's Avatar
71 cutlass convertible
I was able to change the pos, cable without dropping the starter. My 13 year old son could fit his hand up there and put the cable on and start the nut. Sometime there are advantages to a father and son project.
Larry
Old Jul 6, 2010 | 03:10 AM
oldbill's Avatar
I guess that my 49 V8 is easier to work on than you late model guys. Jacked it up, put a a short extension and wobble socket on the nut, changed it in about 10 minutes without removing anything else..
Old Jul 7, 2010 | 07:35 PM
lol well today I changed the cables it was not fun at all had the car on the lift negative cable was an easy change the positive cable as you all said....I had to drop the starter luckily there were no shims : ) so I didnt have to deal with that that thing weighs a ton when ur trying to screw the gosh dang screws back in I had the starter in one hand and breaker bar in the other and went to town haha. all in all fun day next transmission fluid.... hmm im also wondering has anyone ever had the problem with thier horn going off when the wheel was turned to far ?
Old Jul 8, 2010 | 04:52 AM
jaunty75's Avatar
Yeah, that has a crank starter, doesn't it?
Old Jul 8, 2010 | 04:59 AM
Oldsguy's Avatar
Past Administrator
Originally Posted by georgiaboy697
...hmm im also wondering has anyone ever had the problem with thier horn going off when the wheel was turned to far ?
It is probably something in the top of the steering wheel. The wire for the horn is routed up the steering column through the middle of the wheel to the switch mechanism where it completes a ground, activating the horn. If that wire is frayed or there is a loose nut or piece of hardware it can cause the horn to blow as you described. Don't try dis-mantling it without a service manual or at least a diagram. With the horn and the turn signal switch in the vicinity it can be a nightmare to re-assemble. The horn switch should be the first thing you see when removing the steering wheel cover though.
Del70
Mar 16, 2013 07:21 PM
gardizzle86
Aug 22, 2011 08:57 PM
cornwallis
Oct 12, 2010 05:42 PM
Del70
Sep 28, 2010 04:21 AM
silverriff
Mar 12, 2010 04:22 PM
