Ignition Switch
Old Apr 26, 2015 | 04:24 PM
Ramirez007's Avatar
Ignition Switch
Need help on replacing an ignition switch for a 74 Olds Delta 88 ?
Old Apr 26, 2015 | 05:30 PM
If you are talking about the electric ignition switch and not the lock cylinder, just drop the column. You'll see the switch on the top side of the column, near the firewall.
Old Apr 26, 2015 | 07:24 PM
+1. You can't miss it. Two screws.
Why do you need to replace it?
Old Apr 27, 2015 | 05:49 AM
oldspackrat's Avatar
Maybe he means the key & tumbler? If so, also easy enough if you have the right tools to pull the steering wheel & lock ring.
Old Apr 27, 2015 | 06:09 AM
As well he may. Of course, we'll never know if he doesn't say that.
And, though it is annoying and painful, I have never had a problem getting the lock ring off without the special tool (I'm a glutton for punishment ).
Old Apr 27, 2015 | 07:45 AM
Which is why I noted that in my first post. The mind reading thing still isn't working.
Wasted
Oct 26, 2018 02:57 PM
Benny Blanco
May 25, 2008 04:17 PM
47 Coupe
May 9, 2008 08:38 AM
mm89olds
Apr 6, 2006 11:03 AM
oldbutgood
Nov 12, 2002 10:00 PM
