How to change ignition switch
Old Oct 13, 2014 | 01:52 PM
drentz's Avatar
could you possibly tell me how you replaced the ignition? I have a 72 442, and I pulled steering wheel and removed turn signal mech, and nothing I could do would release the cylinder.
Old Oct 13, 2014 | 02:51 PM
70cutty's Avatar
Beer Connoisseur
drentz welcome to CO.
Start your own thread it will get more exposure and your question will be answered faster.
Old Oct 13, 2014 | 02:53 PM
HWYSTR455's Avatar
<<<@!1!@>>>
This one isn't too bad:
Old Oct 13, 2014 | 03:02 PM
Welcome to the site, I moved your thread.
Old Oct 13, 2014 | 03:05 PM
drentz's Avatar
Thanks!!!!
HWYSTR455's Avatar
Cool, thank you!
drentz - You removed the 2 retaining screws? Or were there no screws?
If there were no screws, it may be the type where there's a window you have to knock out and push a spring loaded retainer. Do you have the new lock? Look at the end and see if it has a spring loaded retainer.
If you have a pic, that would be good.
Old Oct 13, 2014 | 03:07 PM
drentz's Avatar
I did remove the screws, and they done nothing. I did hear something about knocking a hole in the column, but I really didn't want to do that. I do have the new cylinder, and it does have some kind of spring loaded mech like you speak of.
Old Oct 13, 2014 | 03:13 PM
mrolds69's Avatar
You will have to make the hole, it's no big deal, it's just metal "flash". Let me find the info..........this is deeper than you want to go...http://www.buickperformanceclub.com/...lumnwobble.htm The pic above the cylinder, the white arrow at the top right, it's that slot you need open. You can do it with a small screwdriver, it's easy.
Old Oct 13, 2014 | 03:27 PM
drentz's Avatar
Thank you. I will give this a shot.
Old Oct 13, 2014 | 03:48 PM
mrolds69's Avatar
You should pull the buzzer switch, too, BEFORE you pull the cylinder. Once that slot is open, you will be right over the tang to push in. Push it, and pull the cyl out.
Old Oct 14, 2014 | 07:26 AM
I ASSUME you are talking about replacing the LOCK CYLINDER. The switch is at the base of the steering column and is operated by a rod from the lock cylinder.
Old Oct 14, 2014 | 08:57 AM
drentz's Avatar
Yes Joe, I am talking about the cylinder.
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
Dragonist
Apr 24, 2011 04:58 PM
Benny Blanco
May 25, 2008 04:17 PM
71cutlasshardtop
Sep 19, 2007 08:01 PM
