help id wire on 66 engine harness
Old Jun 7, 2018 | 09:14 AM
mazey's Avatar
66 cutlass convertible, replaces the fuse panel/dash harness last year. Now i looking at the engine harness that plugs into back of fuse panel. one wire is black with white stripe. The other is a fabric/cloth white with small black stripe. These wires along with other unused wires were taped off years ago .Black wire is only about 16 inches long with a connector. None of my wire diagrams show these wires. Trying to clean up some old work. Thanks
Old Jun 7, 2018 | 09:18 AM
mazey's Avatar
this pic shows the firewall fuse connection, the missing one on left is one im asking about.
Old Jun 7, 2018 | 09:19 AM
mazey's Avatar
heres pic
Old Jun 7, 2018 | 09:21 AM
mazey's Avatar
this is diagram im going off of. i can match every wire except these two
File Type: png
Old Jun 7, 2018 | 09:48 AM
The cloth one is the resistance wire that goes to the coil + terminal. Black supplies ground to the horn relay from the horn button?
Old Jun 7, 2018 | 10:22 AM
mazey's Avatar
horn works ok, just actually got it working correctly off steering wheel, for past 31 years i had an auxiiary button under dash. And ive always had her in car too.
Old Jun 7, 2018 | 10:23 AM
mazey's Avatar
only black white stripe i see is part of brake lite circuit,ut they also work properly
Old Jun 7, 2018 | 10:38 AM
mazey's Avatar
it has a connector on end and is same length as the wiper motor wiring, is it part of the wipers? Or what else would be near the wiper motor?
Old Jun 7, 2018 | 11:00 AM
Could be wiper, you have yellow, dark blue, and light blue there?
Old Jun 7, 2018 | 11:20 AM
mazey's Avatar
heres a pic of wiper wiring along the black wire. similiar length.
Old Jun 7, 2018 | 11:21 AM
mazey's Avatar
here it is
Old Jun 7, 2018 | 11:23 AM
m371961's Avatar
I'm just guessing but could it be wire for underhood light?
Old Jun 7, 2018 | 11:46 AM
^^^THIS! We have a winner.
Old Jun 7, 2018 | 12:02 PM
m371961's Avatar
Even a dead clock is right twice a day, unless it is digital.
Do they color it the same as parking lights? I don't have diagram for it.
Old Jun 7, 2018 | 12:23 PM
mazey's Avatar
possibility. don't see it listed on any diagrams.mine never had on, maybe an option?
Old Jun 7, 2018 | 12:27 PM
I just got home and looked at mine, a 67. Makes sense, mine does not have an underhood light, so apparently no black wire either.
Old Jun 7, 2018 | 03:07 PM
66-3X2 442's Avatar
I've never seen an under hood light on a 66 but then again,I haven't seen all of them either.
Old Jun 7, 2018 | 05:23 PM
nicks1966's Avatar
I checked my original and the my American auto wire reproduction harness and the black with with stripe goes to the wiper motor. Black wire is not on the 66 wiring diagram, I checked my 67 diagram and the black wire is on it. Must be something to do with the round vs rectangular motor.
Old Jun 7, 2018 | 06:25 PM
I looked at my windshield wiper motor and the black wire w/white stripe does indeed go to it as a single plug.
Old Jun 8, 2018 | 10:10 AM
mazey's Avatar
thanks, i removed wiper motor a few years ago, burnt out, (rain-x works great). and bundled all the wiper wiring together. ill figure it out when i get around to replacing motor.
Old Jun 8, 2018 | 10:17 AM
mazey's Avatar
was surprised i couldnt find listing in diagrams
craig442
Sep 2, 2016 07:45 PM
ej69
Oct 14, 2015 07:19 PM
1968_Post
Aug 28, 2014 03:17 PM
dmiron
Sep 13, 2012 08:46 AM
wcwhite
Oct 26, 2011 05:10 PM
