fuel tank sending unit
Old May 10, 2019 | 04:49 AM
ALT's Avatar
ALT
Red face fuel tank sending unit
Hi I'm having an issue with my fuel gauge on my 1970 olds cutlass that I'm currently restoring. It was working fine after I installed the new tank and sending unit, now it nose dives to E with the key on. Not sure how the older systems work, i know the tan wire goes to the float, but i have no voltage coming from at all. I could sure use some help....
Old May 10, 2019 | 05:28 AM
The float is the ground side of the meter circuit. The reason its going to E is you have a short to ground in the tan sender wire. If you remove the wire from the sender it should go past F with the key on.
Old May 10, 2019 | 05:43 AM
ALT's Avatar
ALT
Thanks Eric, I'm going to look for that short I will keep you informed .
deadeyejedi
May 3, 2019 08:57 AM
70cutty
Apr 15, 2019 05:04 PM
golden rocket
Aug 30, 2018 11:13 AM
abrasv
Feb 26, 2018 10:25 AM
hamm36
Jan 1, 2009 08:21 PM
