specs for resistor board on fuel tank sending unit
Old Aug 30, 2018 | 10:20 AM
golden rocket's Avatar
golden rocket
1967 Delmont 88 425 2 door hardtop with factory air conditioning. Pulled fuel tank and removed sending unit, removed sock and cover, per shop manual. What are the specifications for the resistor board on the sending unit. Have been working, off and on, in trying to get fuel gage to read correctly. Indicator on the gage reads way past full, have cleaned all the grounds, I could find. even checked the grounds for the fuel tank, and I'm stumped. Any advice is appreciated.
Mike
Old Aug 30, 2018 | 10:34 AM
You have an open circuit. Do this test, remove the wire from the sender and just leave it hanging with the key on, it will read past full (open circuit). If you ground that same wire it should drive the fuel gauge to E.
The resistor board on the gauge is to dampen the movement.
Old Aug 30, 2018 | 11:13 AM
1964-newer GM cars use a 0-90 ohm potentiometer in the sending unit.
ALT
May 10, 2019 05:43 AM
deadeyejedi
May 3, 2019 08:57 AM
70cutty
Apr 15, 2019 05:04 PM
MarkR
Apr 29, 2010 12:32 PM
hamm36
Jan 1, 2009 08:21 PM
