Temp or oil pressure
Old May 10th, 2019, 11:36 PM
Julle's Avatar
Hi, can someone please tell me if the green wire from the engine block is a temp or oil pressure sensor? Cutlass Supreme Brougham 1978.
Julle is offline
Old May 11th, 2019, 04:22 AM
In years past green was temp, blue is oil pressure.
oldcutlass is offline
Old May 11th, 2019, 06:05 AM
Julle's Avatar
Thanks!
Julle is offline
Old May 11th, 2019, 12:01 PM
jaunty75's Avatar
Ground the wire with the ignition on and see which light on the dash lights up.
jaunty75 is offline
Old May 11th, 2019, 02:08 PM
72455442RA's Avatar
thats chevys water temp
oil pressure is by the distributor
72455442RA is offline
Old May 11th, 2019, 02:43 PM
RandyS's Avatar
Oil pressure is at the front of the block.
RandyS is offline
Old May 11th, 2019, 04:19 PM
Not on a Chevy motor. Look again at the picture in the first post.
joe_padavano is offline
Old May 11th, 2019, 05:01 PM
RandyS's Avatar
Oops, my bad.
RandyS is offline
Old May 14th, 2019, 09:25 PM
Julle's Avatar
I could not get a correct signal from the green cable so I installed an adapter. It works fine
Julle is offline
Old May 14th, 2019, 09:47 PM
If you grounded the green wire it should light the temp light of peg a gauge, depending on which you have. If that happened, then you can just replace the sender.
nanardos
September 1st, 2013 09:41 AM
kanotix
April 4th, 2013 03:15 PM
Finn5033
April 10th, 2012 09:23 AM
1976Oldswagon
December 31st, 2011 12:50 PM
Thomas Simcich
October 13th, 2010 11:28 AM
Quick Reply: Temp or oil pressure
