flashers on 1970 Ralley wont work?
Old October 7th, 2019, 09:52 AM
Hondo's Avatar
Exclamation flashers on 1970 Ralley wont work?
hello everyone, 1970 Rallye.... I got all the lights to go on... but at least I found the brake pedal arm button was not connected. but still can't get the Flasher to work? does anyone have any suggestions?
thank you
Hondo is offline
Old October 7th, 2019, 10:13 AM
Which flasher, directional or hazard lights? The flasher unit located near the steering column is for the direction.al, the mounted on the fuse block is the hazards. Have you changed the one that corresponds to your issue? They can be swapped for troubleshooting
oldcutlass is offline
Old October 8th, 2019, 03:59 AM
Hondo's Avatar
Exclamation 1970 Ralley Flasher ssembly
Hello,
shouldn't the FLASHER ASSEMBLY just pop out of the fuse terminal? Flashers dont work so I fugured taking it out spraying some contact cleaner and plugging it back in?
Thank you
Hondo is offline
Old October 8th, 2019, 04:07 AM
scrappie's Avatar
Sometimes the flasher itself needs replacing. Do they just stay on or nothing at all?
scrappie is offline
Old October 8th, 2019, 06:19 AM
I merged your 2 threads. Yes the hazard light flasher can just pulls out.
Old October 8th, 2019, 06:28 AM
Hondo's Avatar
thank you oldcutlass, trying to pull out but the sucker wont move? it feels like im going break the fuse panel?
Hondo is offline
Old October 8th, 2019, 07:05 AM
Disconnect the battery and gently pry under it with a small screw driver.
Old October 8th, 2019, 09:43 AM
Hondo's Avatar
Thank you again oldcutlas
Hondo is offline
Old October 8th, 2019, 11:23 AM
The flasher can also be removed by gently rocking the unit side to side while pulling straight out.
Allan R is offline
Old October 8th, 2019, 02:31 PM
Hondo's Avatar
ALLAN R. Tried that approach and felt like it was going to disintegration in my hand.
Hondo is offline
Old October 8th, 2019, 02:47 PM
Try grabbing it & wiggling it out w/ a pair of channel lock pliers.
Vintage Chief is online now
Old October 8th, 2019, 02:51 PM
Hondo's Avatar
I guess you want me to purchase a new FLASHER ASSEMBLY. Vintage Chief LOL
Hondo is offline
Old October 8th, 2019, 03:00 PM
Without a picture, it's difficult to know the condition of your fuse box. I've seen some where I've questioned how anything at all is working.
At any rate, if you're going to these lengths to remove the flasher ensure you disconnect the battery as (the other) Eric has already mentioned.
Old October 8th, 2019, 03:14 PM
Hondo's Avatar
Exclamation Fuse Box
Here is the picture of the fuse and also made a drawing on it.
Hondo is offline
Old October 8th, 2019, 03:28 PM
Not so bad. A little worse than mine - several fuse holders are showing rust/pitting, but I've seen seriously worse cases. The flasher most likely hasn't been changed in several decades - it's going to take some effort - probably has corrosion/oxidation in the socket and on the flasher socket contacts - be persuasive.
And, please BTW, don't spray contact cleaner on the flasher once you get it removed - buy a brand new flasher (and, apply a small amount of dielectric grease to the contacts).
Old October 8th, 2019, 03:32 PM
Hondo's Avatar
Thank you Sir.. Vintage Chief
Hondo is offline
Joah_from_Alberta
September 2nd, 2013 03:37 PM
davesdelta
August 13th, 2012 07:18 PM
kevin.horton
March 26th, 2012 07:12 PM
Pghstarsky
December 30th, 2007 02:04 PM
Pghstarsky
October 15th, 2007 04:44 AM
Quick Reply: flashers on 1970 Ralley wont work?
