flashers on 1970 Ralley wont work?
hello everyone, 1970 Rallye.... I got all the lights to go on... but at least I found the brake pedal arm button was not connected. but still can't get the Flasher to work? does anyone have any suggestions?
thank you
thank you
Which flasher, directional or hazard lights? The flasher unit located near the steering column is for the direction.al, the mounted on the fuse block is the hazards. Have you changed the one that corresponds to your issue? They can be swapped for troubleshooting
1970 Ralley Flasher ssembly
Hello,
shouldn't the FLASHER ASSEMBLY just pop out of the fuse terminal? Flashers dont work so I fugured taking it out spraying some contact cleaner and plugging it back in?
Thank you
Thank you
At any rate, if you're going to these lengths to remove the flasher ensure you disconnect the battery as (the other) Eric has already mentioned.
Not so bad. A little worse than mine - several fuse holders are showing rust/pitting, but I've seen seriously worse cases. The flasher most likely hasn't been changed in several decades - it's going to take some effort - probably has corrosion/oxidation in the socket and on the flasher socket contacts - be persuasive.
And, please BTW, don't spray contact cleaner on the flasher once you get it removed - buy a brand new flasher (and, apply a small amount of dielectric grease to the contacts).
davesdelta
August 13th, 2012 07:18 PM
