Electronic distributor for 55 rocket 88
Old Feb 23, 2015 | 10:03 PM
ortarheel's Avatar
I have a 1955 rocket 88 with the original engine. A 324? I'm looking to get rid of the points and put in an electronic distributor. All I've been able to locate is a conversion kit for my current unit. Not a new distributor. Is my engine compatible with a new unit? Thanks!
Old Feb 24, 2015 | 03:52 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I don't think you will find a new unit for your car. I have a Pertronix in my 54 with the Pertronix coil and it works great.
Old Feb 24, 2015 | 08:40 AM
ortarheel's Avatar
Thanks Red!
Old Feb 26, 2015 | 06:37 AM
Tedd Thompson's Avatar
Pertronix is a easy good way to go but unless you are clueless about point maintenance and can't set up a set of points there is little or no advantage going to a pointless system. The only Pretronix system I have used (small block Chevy) the modem crapped out and left me stranded in the sticks.I know this doesn't happen often but something to keep in mind. Also keep your old set of points in the glove box so you can use them if this does happen..... Just my experience... Tedd
PS . And yes you have a 324 in your 55.
Old Feb 26, 2015 | 08:33 AM
redoldsman's Avatar
There are about a dozen threads on here debating this subject. I hope this does not turn into another. I could not be happier or more satisfied with a product.
rcktdoc
Mar 23, 2014 05:46 AM
BradyB
Sep 20, 2012 11:11 AM
bigbrother
17
Mar 11, 2012 06:45 PM
BigTrav
Nov 23, 2010 06:58 PM
1973cutlass
Oct 12, 2010 12:27 PM
