Edelbrock 1406 install
Old March 25th, 2009, 12:34 AM
christine fury
Guest
Posts: n/a
Help, I have a '72 Cutlass Supreme, with a 350 (K VIN) I recently purchased an Edelbrock 1406 w/electric choke. Any ideas installing the red wire to an ignition key activated 12V source (other than coil or alternator) as stipulated by Edelbrock?
Old March 25th, 2009, 05:42 AM
72greensupreme's Avatar
there are all kinds of switched "hot" wires under the hood. i would get a fluke and test some wires that are near the carb. make sure to test them with the car on and off to make sure it is hot only when the car ignition is on. I have an edelbrock on my 72 but it is manual choke so i just took mine off. it starts hard when its cold, but runs like a champ once warmed up.
72greensupreme is offline
Old March 25th, 2009, 06:50 AM
Redog's Avatar
I ran a the wire to my ingtion coil, but like he said. there are a few hot wires you can run to
Redog is offline
Old March 25th, 2009, 09:34 AM
The best way to do this is to route the +12V wire through an oil pressure switch first so that the choke is only active if the engine is actually running. I use this one:
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Oil-Pressure-Switch-Sender-ACDelco_18051408-P_417_R|GRPSESWAMS_2938444___
The outer two terminals are the ones to use for the choke. If you have an OIL idiot light, the center terminal will operate the light.
joe_padavano is offline
Old March 25th, 2009, 12:04 PM
christine fury
Guest
Posts: n/a
411
Thanks Green supreme, Red Dog, Joe P.; good looking out. I realize Edelbrock doesn't want to assume any liabilities, however, it would sure help if they would offer suggestion out of the box.
Hey, how can I ad a pic to my account? Not sure how all this stuff works.
Old March 25th, 2009, 12:57 PM
Past Administrator
Oldsguy's Avatar
click on "user cp" which is an option on the menu bar above just to the left of FAQ. Then on the left margin there are options for editing. Select edit avatar and upload the picture you want, just be sure to select a picture that is less than 97k.
Oldsguy is offline
Old March 25th, 2009, 01:19 PM
Registered
Bluevista's Avatar
Welcome. Should have stuck with the Q-Jet.
Fury is one of my my all time favorite TV shows, any relation? It was on right before Sky King on Saturday mornings.
Bluevista is offline
Old March 25th, 2009, 02:25 PM
christine fury
Guest
Posts: n/a
Thanks OG, I had to send a message to tech support because it wouldn't work. Something about limited access.
Hey BlueV. No relation to the late 50's western with the Stallion, however, more of a fan of the '58 Plymouth Fury as depicted in "Christine".
Old March 25th, 2009, 03:18 PM
Registered
Bluevista's Avatar
About the same year anyway.
I loved that horse.
Christine the Fury, I get it now.
I took my driver's test in a 1964 Plymouth Fury wagon.
Old March 6th, 2012, 12:22 PM
dave84's Avatar
I too am having a small problem with the red wire. Edelbrock's video tech says to tap into the fuse box under the dash. My problem is I do not have the wire that was supposed to come with the 1406 Carb electric choke. I'm trying to get one, but what's a good DIY solution? Joe I know your loving all my posts lately
dave84 is offline
Old March 6th, 2012, 01:26 PM
TripDeuces's Avatar
Sky King, holy cow. I met him in El Paso around 63-64. He seemed so big in person with that blue suit and white/beige Stetson. Ah to be young again
TripDeuces is offline
Old March 6th, 2012, 01:40 PM
I just ran a wire and stabbed a post in my fuse box to come on when the key was on. You can also tap into the wiper motor hot lead. Under no circumstances use the hot off the ignition coil.
oldcutlass is offline
Old March 6th, 2012, 03:26 PM
You might want to check out this thread:
https://classicoldsmobile.com/forums...ke-wiring.html
Old March 7th, 2012, 09:36 AM
dave84's Avatar
I picked up 12 gauge wire and a 30 amp wire-through fuse. Gunna pick up and oil switch ps-64 and go with that method. The switch is a direct replacement to the original on the 67 330?
dave84 is offline
Old March 7th, 2012, 07:29 PM
jpc647's Avatar
Off topic, but what intake manifold are you matching up the 1406 carb with? The OEM one?
jpc647 is offline
Old March 7th, 2012, 07:58 PM
dave84's Avatar
yea, an original 4bbl i grabbed.
dave84 is offline
Old March 13th, 2017, 05:54 AM
cutlassefi's Avatar
Not at all.
cutlassefi is online now
Finn5033
June 8th, 2012 07:41 AM
jimjr
January 17th, 2010 11:48 AM
jimjr
August 20th, 2009 06:25 AM
agtw31
April 11th, 2009 06:57 AM
Huron
July 9th, 2007 11:56 AM
Quick Reply: Edelbrock 1406 install
