Dim dash lights
Not sure where the ground is was looking in my manual. As for the bulbs how many am i looking for:
1 speedometer
2 Radio
3 Glove box
4 fuel gauge
5 ash tray
do i need to pyll the warning light cluster assuming there would be 4 bulbs for gen oil hot cold.
Also if the ignition had a bulb i think mine is missing
1 speedometer
2 Radio
3 Glove box
4 fuel gauge
5 ash tray
I changed all of mine last year. My service manual lists what bulbs and how many. Somewhere I learned of this company that their bulbs are brighter, I didn't see much of a difference but at least they are all working. https://www.jacksonelectricsupply.com/
You can't beat the price.
I want to my local canadian tire and for 2 bulbs it was 6.59. I want to order them online what exactly am i looking for. Going to order 11 bulbs for the cluster. Manual says 30,31,32 series 158. Does anyone have any part numbers.
168 or 194 miniature bulbs should work in everything except possibly the clock. Trying to remember what bulb the ignition switch lamp uses. A J88 may not have it.
What manual are you using? 30-31-32 series are Cutlass. A Jetstar 88 is 33 series and will use the same lamps and dashboard as the other full-size cars- Dynamic 88 and Jetstar 1 (34), Super 88 (35), Starfire (36) and Ninety Eight (38).
I might be completely off-base here, but a lot of the cars of the 60s era had headlight switches that also acted as a rheostat for the dash lights...rotate the dash switch to the left, the dash lights get brighter...rotate the dash switch to the right, the dash lights get dimmer to completely extinguished. Is that a possible cause for your dim dash lights?
On the other hand, I know the dash lights on my '68 and '69 4-4-2 convertibles don't seem as bright as they used to be and can be hard to read, even at night at full brilliancy. Even the gauges, and especially the tach, seem hard to read at times even in full daylight. I'm thinking it's just my old eyes!
Randy C.
Randy C.
Christophe2m6
October 31st, 2014 11:37 AM
