Diagnose old distributor cap/rotor
Old Jul 13, 2013 | 04:43 PM
coldfire's Avatar
Just did a tune-up, replaced cap & rotor... this is what was lurking
I don't know the age/mileage of the one I took off, but that can't be "normal" wear & tear right? I don't want that to happen to the new one I put on!
Old Jul 13, 2013 | 04:45 PM
coldfire's Avatar
Here's a bigger pic of the cap -- the center is sort of melted/deformed
Old Jul 13, 2013 | 04:56 PM
Grace Stinespring-Welch's Avatar
you might want to get a new coil
Old Jul 13, 2013 | 05:18 PM
kitfoxdave's Avatar
x2 on the coil... I have been there, yours actually looks better than the one I had from PO.... Ran MUCH better after!
Old Jul 13, 2013 | 05:24 PM
The spring wore out and then the contact arced on the rotor creating heat and meltage. The coil is probably still good if it's not melted around the contact point.
Old Jul 14, 2013 | 04:02 AM
kitfoxdave's Avatar
replace it now, or replace it shortly... you Will likely be replacing it soon!
Old Jul 14, 2013 | 09:28 PM
BILL DEMMER's Avatar
Just the facts...
if the coil center contact isn't burned, corroded, or otherwise damaged, run it.
bill
Old Jul 15, 2013 | 12:43 AM
coldfire's Avatar
I'll have to pull it off & take a look, see if it's damaged at all
brown7373
Sep 12, 2014 06:51 AM
brown7373
Aug 22, 2014 07:00 PM
72CUTTY
Mar 23, 2014 10:52 PM
BDK1973
Jun 29, 2012 08:33 AM
deaddds
Sep 23, 2009 05:33 PM
