Courtesy Lamps Bracket?
Old Jul 29, 2016 | 11:34 PM
Microreedy's Avatar
I'm doing a frame off restoration on a 71 442. I am currently putting in the wiring harnesses. Does anyone know if the is a bushing or bracket for the driver and passenger courtesy lamp. Mine keep grounding out to the car body and blowing a fuse. Isolated it from the body and everything works fine. Any help would be appreciated
Old Jul 30, 2016 | 07:23 AM
oldspackrat's Avatar
If you're talking about the footwell lights then they snap directly into the lower metal part of the dash. If you are blowing a fuse when you insert them then you have an issue with the wiring to them.
dsolomon
Mar 14, 2012 09:32 AM
sklbndt
Feb 12, 2009 06:36 PM
Scotty B
Sep 24, 2008 07:02 AM
FATRATMATT
Aug 27, 2008 07:31 PM
DuezPaid
Nov 3, 2007 01:21 AM
