Courtesy Lamps Bracket?
I'm doing a frame off restoration on a 71 442. I am currently putting in the wiring harnesses. Does anyone know if the is a bushing or bracket for the driver and passenger courtesy lamp. Mine keep grounding out to the car body and blowing a fuse. Isolated it from the body and everything works fine. Any help would be appreciated
If you're talking about the footwell lights then they snap directly into the lower metal part of the dash. If you are blowing a fuse when you insert them then you have an issue with the wiring to them.
DuezPaid
Nov 3, 2007 01:21 AM
