"Corrected" HEI cap
Old Jul 15, 2008 | 11:20 AM
74 Omega's Avatar
"Corrected" HEI cap
Has any one ever used one of these?
ACCEL makes a corrected HEI GM cap and rotor kit that is supposed to put all the EVEN wires on one side and then all the ODD wires on the other to prevent the "tangled up" look.
http://www.raceindustry.com/part-sho...i-cap-kit.html
Old Jul 15, 2008 | 12:34 PM
aliensatemybuick's Avatar
"me somebody" site member
A friend of mine tried one on LT1 powered Nova, but had some trouble (it "failed" somehow) so he ended up going back to a standard cap.
Old Jul 15, 2008 | 01:13 PM
rocketraider's Avatar
Oldsdruid
Believe it or not, the plug wires are routed in a certain way to reduce crossfiring and inductive electrical interference. I've seen it addressed in some early 60s Service Guilds and Tech Bulletins.
Old Jul 15, 2008 | 02:03 PM
Yes, you don't want the wires for successive cylinders in the firing order to run parallel to each other. 5 and 7 is the pair you need to look out for on an Olds. 8 and 4 to a lesser extent.
Old Jul 15, 2008 | 02:10 PM
You can get wire looms from the auto parts store that can eliminate that nasty look. All it takes is a little bit of frequency modulation...
joepenoso
Jun 4, 2014 01:56 PM
oldsmobilty
Dec 2, 2013 07:55 AM
oldscruiser
Feb 15, 2011 12:44 AM
72rocket
Dec 30, 2008 08:31 AM
