Can't turn distributor
Old Jun 29, 2010 | 07:30 AM
mauls's Avatar
Green Horn
My car is off timing, and I'm trying to turn the distributor but cannot get it to budge. I've even put some PB blaster on it and still nothing. I can get it to wobble but it will not turn either direction.
Any advice
It's on a 1965 jetstar 88, 260 motor.
Old Jun 29, 2010 | 07:59 AM
Oldsmaniac's Avatar
Had that problem on an 83 Hurst. Lots of soaking and tapping and pipe wrench or the like on the shaft and tapping on the wrench. Took about an hour but got it loose.
Old Jun 29, 2010 | 08:13 AM
Originally Posted by mauls
Any advice
Advice? Yeah. This is a sign from on high that it's time to lose the 260.
Old Jun 29, 2010 | 08:16 AM
mauls's Avatar
Green Horn
Thanks for the help! I'll keep wrenchin on it
If i could take it out now I would trust me! I'm currently building a 425, stated a thread in the big block section.
I'd just like to cruise around (downhill) in the mean time
Old Jun 29, 2010 | 11:18 AM
rocketraider's Avatar
Oldsdruid
You have plenty of room under there. I think those 260 distributors had the square shank like earlier ones did. Get a big-*** open end wrench that fits it, juice it up with the penetrant, and then wale away on the wrench with a suitable hammer. It should break loose.
If not enough room to wale, go to Harbor Freight or somewhere and get a crowsfoot wrench in the size you need, then use an appropriately sized extension and breaker bar. The suitable BFH may help here too.
See, Oldsmobile was looking out for us down the road by putting that square shank area on the distributor.
Old Jun 30, 2010 | 03:13 PM
mauls's Avatar
Green Horn
Yes it has the square shank, Still can't get a good grab on it, I can't get a low enough angle cause the carb is in the way, i may have to remove the carb.
jpaulwhite
Oct 5, 2023 05:10 PM
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
chris83
Aug 18, 2012 01:47 PM
old44272
Mar 28, 2011 09:21 AM
