A/C Delete Blower Motor Resistor
I removed the A/C from my car and installed the after market delete plate. Where do you mount the blower motor resistor? It used to plug into the side of the condensor box.
If you installed a plate so you can still use the heater and blower, the plate will need a hole cut in it for the resistor.
The resistor MUST be installed in the blower's airflow (close to the motor) to keep it cool, otherwise it's magic smoke will be released quickly...
Resistor location on AC Delete
I hope this works in this spot cause this is where mine is now...I think I had to lengthen the wires to get it to reach from the AC control panel? I think thats where it came from?? I did it a couple of months back and can't remember...getting old is hell.
Tom
68 442
70 F85
Tom
68 442
70 F85
I think that should work okay - it is in the airflow. Ideally it would have been on the steep angled up section for max flow.
