Bulb type 557
Old July 8th, 2018, 02:26 PM
GTA_doum's Avatar
Question Bulb type 557
Hello,
I have an Oldsmobile Cutlass Supreme 1972. I am looking for the bulbs in the fuel gauge unit, with the dumb lights. For the engine temp, GM book indicates to use a bulb type 557 :
"Engine Temp. Indicator (Flashing) (Exc. Rocket Rallye Pack) 557 Can. Pow. 3", 3 is the same as bulb type 168.
Is the 557 bulb a bulb that flashes by itself? Is there a new number for this bulb or it does not exist anymore?
GTA_doum is offline
Old July 8th, 2018, 02:42 PM
Oldsdruid
rocketraider's Avatar
Olds used those a lot in early 70s- idea being that a flashing light would emphasize "you need to stop the engine now". My 69 Toronado has one of these- there's a hot light, and in same pod a flashing "STOP ENGINE" light that comes on if temp goes way high. SE light is triggered by a sender in a left-side cylinder head bolt.
I think it may be an obsolete bulb number and don't know if there's a modern cross-reference. A 194 or 168 will function just fine as a warning lamp, you just won't have the flashing function.
Note to junkyard scroungers- you may want to start pulling these flasher lamps from 68-70 Toros, 71-73 B-C-E body, and any other car that uses them.
rocketraider is offline
navvet
April 23rd, 2016 04:54 PM
mitchy
February 8th, 2016 09:34 AM
68442Convertible
July 5th, 2012 10:25 AM
snowballs442
December 24th, 2010 08:35 AM
FATRATMATT
June 18th, 2008 08:05 AM
Quick Reply: Bulb type 557
