Broken pins on back of gauge/speed cluster
Old April 10th, 2013 | 06:22 PM
Like the title says, when I disconnected the harness from the gage cluster a few of the pins stayed in the connector. I had a moment of McGyverism, I went to a GOOD hardware store (not Lowe's or Menard's!) and found that 2.5mmX12mm screws are a perfect fit in the holes in the circuit board. I removed all the loose pins, installed screws and nuts, added a small dab of solder, and reassembled. Better than stock!
Old April 10th, 2013 | 07:52 PM
rocketraider's Avatar
Oldsdruid
One of the guys on 73-77olds.com had a neat writeup with pics of doing exactly that. Nothing like a little ingenuity to keep your stuff functioning!
Old April 10th, 2013 | 07:55 PM
RetroRanger's Avatar
72 Olds CS
nice matt those pins arent on there too good at all. when I got my car some guage lights never worked even after replacing bulbs, when I replaced the dash I found loose pins and one pin was miscrimped on the board, I had a spare column shift speedo and the board from that is the same as the floor shift speedo board so I just swapped them...nice to know a solid fix thanks for posting
Old April 23rd, 2016 | 08:04 AM
Octania's Avatar
put some silicone grease on the pins to avert corrosion and stickage in the future.
hueveaj
February 23rd, 2014 06:53 PM
Beob
October 2nd, 2012 03:51 AM
ViceGuy
February 17th, 2009 11:45 AM
HAFROD
March 15th, 2007 12:32 AM
Quick Reply: Broken pins on back of gauge/speed cluster
