Faulty gas gauge or sending unit?
Old Apr 23, 2016 | 11:36 AM
Gunmars's Avatar
I have a 1971 Supreme that recently the gas gauge constantly reads empty. Replaced sending unit about 2 years ago during restoration.
1. Unplugged the brown wire in trunk and gauge goes past full.
2. Grounded the brown wire and gauge shows 3/4 tank.
3. Switch on headlights and gauge drops below empty.
4. With brown wire plugged in and switch on it reads 16 ohms for a second then meter drops back to 0 ohms.
5. Checked and cleaned grounds, brown wire still reads 16 ohms then drops.
6. Drained tank of fuel & got about 7 gallons out of it, checked sending unit terminals and brown wire now shows 11.2 ohms constant
7. To cover all bases I checked voltage of brown wire at gauge and in trunk and it reads 2v. Don't know if that matters or not.
I am confused and way past my expertise in electrical with this situation. Do I have a bad gauge , sending unit or other electrical issue? Thanks
Old Apr 23, 2016 | 01:07 PM
When you turn on the headlights and the gauge drops, does adjusting the dash light rheostat change the reading?
Read these:
https://classicoldsmobile.com/forums...e-problem.html
https://classicoldsmobile.com/forums...ild-check.html
https://classicoldsmobile.com/forums...e-out-car.html
Del70
Nov 3, 2012 06:24 AM
Del70
Sep 9, 2012 03:07 PM
Del70
Sep 7, 2012 08:30 AM
KDW
Dec 12, 2011 08:57 AM
