Blower motor testing
I've been looking for the answer to this all day. Nothing online and nothing in the CSM that I can find.
I want to test my blower motor before I put the inner wheel well back in but can't figure out how to hook it up. Purple wire is the power feed (through resistor) but where do I ground it? I'm using the charged car battery for juice and jumper cables off an old battery charger. I watched Rob's video but I can't make out the connection.
Thanks guys.
Thanks guys.
Okay, got it. Power from batter to resistor but ground from batter to resistor housing. So is that what I screw the ground strap to for installation, the resistor mounting screw? I'll get a pic in a sec.
Faster!
Wise! (No questions, please! Search the "What have you done to your Oldsmobile today" thread...)
Ground comes through a short cable from the firewall nearby, see image. Obviously the plastic/fibre air duct is not ground.
Can't blame you for wanting to cut a hole. I don't want to go through this again. Motor tested fine but I found a bad leak. Seems the caulk fell out of place when I was putting the box back on. Of course it was right against the inner fender. Nothing like caulking with a screwdriver
