blinkers not working
Old Aug 27, 2023 | 02:29 PM
1976Olds's Avatar
I have a 76 cutlass supreme and all my blinkers quit working, the indicator comes on but does not blink but the hazards do. I have replaced the 2 prong flasher in the fuse box and that didnt help any, there is what looks to be a 3 prong flasher hanging near that but i cant find it online or at any parts stores. any help in diagnosing this issue would be greatly appreciated. if it would help i can attach a picture of the 3 prong flasher when i get a minute. TIA
Old Aug 27, 2023 | 02:34 PM
The one on the fuse block is for the 4 ways, there is another by the steering column on a pigtail.
Old Aug 27, 2023 | 02:38 PM
1976Olds's Avatar
is that one a 2 wire flasher
Old Aug 27, 2023 | 02:40 PM
It's the same as the one in the fuse block and they are interchangeable.
Old Aug 27, 2023 | 02:44 PM
1976Olds's Avatar
I'll have to check that out.
Old Aug 28, 2023 | 06:36 AM
The turn signal circuit is designed such that if a bulb is burned out, the indicator comes on but does not blink. Have you verified that the bulbs are good? Note that an open circuit in the wiring will act the same as a burned out bulb.
Old Aug 28, 2023 | 03:44 PM
1976Olds's Avatar
I haven’t checked the side markers but the front and rear lights are good. I would have thought it would just blink fast if there was a bad bulb but I’m used to newer cars
Old Aug 28, 2023 | 03:58 PM
Blinker fluid?
Old Aug 30, 2023 | 08:01 AM
Oldsguy's Avatar
Past Administrator
Norm, that stuff is gold now, very hard to come by. Almost as rare as 50 ft. of flight line.
htrdlncn
Jul 15, 2023 08:36 AM
dc2x4drvr
May 30, 2016 03:30 PM
70Cutlass_408
Aug 18, 2014 06:00 PM
patmac
Jun 29, 2014 06:48 AM
442dreamer
Mar 26, 2012 08:03 AM
