Alternator Upgrade Part Number Request
Old Feb 28, 2017 | 04:26 PM
RROLDSX's Avatar
I would like to upgrade my 69 442 year internally regulated open face alternator to a higher output one. I've read through the alternator upgrade sticky but gathered a 1990 Delta alternator was suggested. When I try to find one on EBay or Rockauto, I get a picture of a 3 point universal alternator with a ribbed pulley.
Does anyone have a part number I can use to order a higher amperage (65-100 amps)?
Thanks, Randy
Old Feb 28, 2017 | 04:56 PM
Qwik71442's Avatar
Full-time Taxpayer
Thanks, Randy
I used this one several times off a 91 corvette 105 Amp. I swap the the pulley from the serpentine to the v groove. Works great
File Type: png
Old Feb 28, 2017 | 05:15 PM
RROLDSX's Avatar
Thanks Qwik, that was quick��. I ordered one just now. Much appreciated!
Old Feb 28, 2017 | 07:26 PM
Qwik71442's Avatar
Full-time Taxpayer
I was tied up when I responded and forgot to add this pigtail adapter will make it an easy swap.
http://www.ebay.com/itm/ACDelco-PT21...xYroVB&vxp=mtr
Old Mar 1, 2017 | 09:08 AM
ReallyWildStuff's Avatar
I am glad you added this post. I was going to say "his harness connections are different than the 91 Corvette".
Old Mar 1, 2017 | 09:40 AM
RROLDSX's Avatar
Ordered the connection as well. Thanks guys.
Old Mar 1, 2017 | 09:52 AM
Thanks, Randy
FYI, the 1990 Delta was FWD. You want the alternator from a 1989-1990 Custom Cruiser, which is RWD and used the 307. That is a 105A CS130.
I'm not sure what additional equipment you have that requires a higher output, but personally I'd keep the open face front housing, and swap it onto a higher output 12SI for appearance sake.
Old Mar 1, 2017 | 11:05 AM
RROLDSX's Avatar
Thanks Joe, didn't really need 105 amps but 37 or so wasn't cutting it. I will keep the original alternator for posterity.
tkw31
Feb 22, 2015 09:07 PM
Kolby66
Drivetrain/Differentials
Jul 14, 2013 09:19 AM
Alg
Jan 1, 2013 05:04 PM
68CO-HURST
Oct 19, 2009 09:14 PM
deweirdt
Jul 21, 2009 08:29 AM
