10dn to 12si alternator conversion
Old Jan 24, 2017 | 07:25 AM
stickman77's Avatar
I currently have an externally regulated 10DN alternator and want to upgrade to a 12SI internally regulated alt. My voltage regulator is a 2 wire, not a 4 wire. Can anybody tell me how to do this conversion properly
Old Jan 24, 2017 | 07:42 AM
2-wire regulator? No such animal, as far as I know.
Pictures.
Welcome to ClassicOlds.
Old Jan 24, 2017 | 09:03 AM
As noted, there is no such thing as a "two wire" external regulator for GM, but that's irrelevant. Find the brown wire from the GEN light. Connect it to the #1 terminal on the 12SI. Run a wire from the horn relay stud to the #2 terminal on the 12SI. Run a heavy gage wire from the horn relay stud to the BATT stud on the 12SI. Done.
Old Jan 24, 2017 | 10:14 AM
stickman77's Avatar
Here is a picture of the plug with only 2 wires.
Old Jan 24, 2017 | 10:19 AM
stellar's Avatar
stellar
check out this animal
Check out this animal. Never say never. GM wiring circuit for Delco regulator number 1119511. I believe these were used on very early GM (not sure what apps) 62 63 64 maybe? It looks like he will need to add a resistor from the switch as there is no indicator lite and only an amp gage . The sense wire can be from whatever point he likes.
Old Jan 24, 2017 | 10:21 AM
It's missing its Light (and excitor) and Rotor wires.
It can't work like that.
If it is working, I would like to see how the terminals are jumped on the back of the regulator, and how they're connected on the alternator.
Anyway, connection of the 12si is simple, as Joe said, but in your case, I would ignore the existing wires and run new wires, because someone did something there that was very unusual, and you can't tell what else they might have done.
Old Jan 24, 2017 | 10:24 AM
That's the wiring for a GENERATOR, not the 10DN ALTERNATOR. "Never" still applies.
stellar's Avatar
stellar
better pic
better pic
Old Jan 24, 2017 | 10:26 AM
better pic
Sorry, still not a 10DN alternator. That's exactly the circuit that was used on my 62 F85 with the original generator. It's also NOT what the OP has on his car.
Old Jan 24, 2017 | 10:30 AM
stellar's Avatar
stellar
Joe check out the diagram. No diodes in a genny. This is for a Delco regulator number 1119511 used with an alternator. Remember this is soon after the switch from gen to alt was made. Note the reg is a single winding unit, similar to what chrysler used at the time.
Old Jan 24, 2017 | 10:35 AM
You're right, sorry. I was not aware of this version. Apparently used on cars with ammeters.
Old Jan 24, 2017 | 10:36 AM
stellar's Avatar
stellar
It sure looks like 2 wires on the reg to me. Open the reg to see if it is one or two coils. If only one it is wired correct. and there will be only one wire going to the alt plug. What year and model car is this?
Old Jan 24, 2017 | 10:38 AM
Joe, as Stellar notes, that's definitely an alternator, and it's definitely got two regulator wires (while the generator cars have three).
That being said, Stellar, I just checked, and the 1961 and '62 both show generators, while the '63 shows the other oddball 3-wire regulator:
I suspect that that 2-wire oddball must have been used on some other GM car, or possibly for such a short period that it somehow didn't make it into the manual.
Either way, his photo seems to show a new (replacement) 4-wire regulator with only two of the wires connected (Field and +12V), and not one of the unusual regulators.
Guess it might help to know the year and model...
Old Jan 24, 2017 | 10:42 AM
The 1119511 was used on Pontiac Tempest, among others. Note that the terminals on the underside of the 111951 that I posted above do not match the schematic in Eric's post. Two of the three terminals are ganged together.
Old Jan 24, 2017 | 10:45 AM
Yes, definitely a different regulator than the half-year '63 system with the separate warning lamp relay.
So, Joe, from your photo, it looks as though the 2-wire regulator looks the same as the 4-wire unit, except that it's missing the #2 "Rotor" terminal.
Old Jan 24, 2017 | 10:52 AM
stellar's Avatar
stellar
Here ya go Joe. A couple more diagrams. Note the 1st one. This reg even looks like a gen reg in size and shape. I think this was the 1st type used after the switch from gen to alt with a lite. I helped a guy with a 62 chevy that used one of these and it was stock .
Old Jan 24, 2017 | 11:02 AM
stellar's Avatar
stellar
Some late 62 had an alt. Some late 68 s had an internal reg where everyone thinks it was used 1st in 69.
Old Jan 24, 2017 | 01:51 PM
stickman77's Avatar
Its a 1965 grand prix, 389 car, with a factory ammeter. The reproduction engine harness sold by M&H lists 2 wire and 4 wire versions for my car if this helps
thanks
Old Jan 24, 2017 | 02:05 PM
Just connect the 12si as Joe suggested, big red wire to big red terminal, and #2 wire to horn relay post (voltage sensor at power distribution point).
The #1 wire typically goes through the GEN light bulb to the IGN terminal of the ignition switch, but since you've got an ammeter and not a light, I would connect it to a decently heavy (at least 3W) resistor of about 10-15Ω, and from there to the IGN terminal, to provide the exciter function that gets the alternator alternating at low RPMs.
Old Jan 24, 2017 | 02:35 PM
stickman77's Avatar
It appears for a '65, there are 2 voltage regulators listed. One for a light (4 wire) and one for a ammeter (2 wire). My car has an ammeter, so the 2 wire appears to be correct for my setup. Would one of the conversion adapters that quality power alternators sells work for my set up?
Old Jan 24, 2017 | 02:48 PM
stellar's Avatar
stellar
So Joe had it nailed as a pontiac. If Stick operates it without the exciter wire it will still charge, but I would recomend you follow Erics advise with the resistor.
Old Jan 24, 2017 | 03:00 PM
Not that I can find on their page.
They do have a converter that would allow you to connect the 10dn plug to the 12si socket, but at $25, plus shipping, it's a whole lot more expensive than just buying a plug from RockAuto ($1.40), or your local parts store (Standard Motor Products HP3870), and you'd have to rewire it anyway.
Old Jan 25, 2017 | 06:03 AM
So if you have an ammeter, you have two concerns.
First, does the output of the 12SI exceed the rating of your ammeter? Most ammeters were either 30A or 60A. If you install a 12SI of 63A or higher output, your ammeter is now a fuse.
Second, you still need the exciter wire, as noted. If you don't have a GEN light, you need to run that wire from the #1 terminal on the 12SI through a resistor (about 35 ohm is plenty) to a switched 12V source.
Old Jan 25, 2017 | 06:17 AM
I just re-checked the schematic, and, yes, the ammeter is wired in series like it should be (It's not inductive like the old F_rd ammeters, or running with a shunt).
But, accuracy and tolerances being what they are, I would suspect that a nominal 63A alternator would be fine with a nominal 60A ammeter. I just wouldn't go any higher than that.
Old Jan 25, 2017 | 08:14 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Interesting, not very often Joe gets stumped. I am pretty happy with my Summit chrome 70 amp 10 DN alternator. The performance tag said 51 amps at idle and 82 amps at cruise. I would assume it would be too much as well. Make sure you get an actual 12si case, the 100 amp 10si alternators don't last.
Old Jan 25, 2017 | 08:18 AM
I know Oldsmobiles, but I don't claim to be expert on other GMs. I've never seen an Olds with this regulator, and I've not seen one in the wild before.
Old Jan 26, 2017 | 12:36 PM
stickman77's Avatar
Guys, if i decided to just upgrade the 10dn from the stock 42amp to a 10dn 63 amp, would the stock wiring and ammeter be able to handle the extra amps?...I can live with the external voltage regulator setup for now. The internal alt conversion with my ammeter setup is a little more than I want to tackle right now
-Stick-
Old Jan 26, 2017 | 12:50 PM
-Stick-
I doubt you can plug a 63A 10DN into that two wire regulator. You'd need to re-wire for a conventional four-wire regulator. It is MUCH easier to simply hook up a 12SI. Unplug the old regulator and alternator. Connect the wire that runs to the threaded BATT terminal on the old alternator to the threaded BATT terminal on the 12SI. Connect the #2 terminal on the 12SI to the BATT terminal also. Splice a 25-35 ohm resistor onto the wire to the #1 terminal, then run a wire from the other side of the resistor to the old regulator connector wire that did NOT connect to the alternator. Done.
When done, it will look something like this:
Old Jan 26, 2017 | 08:26 PM
Aw, c'mon, Joe. At least have him run the sensor wire to the horn relay post.
Looping it back to the output stud is so... Geep-y.
Old Jan 27, 2017 | 03:18 AM
stellar's Avatar
stellar
Some Cadillacs had the sense (#2) wired from the factory directly to the output post as shown in Joes pic.
If he replaces the 10DN stator with a 63 amp stator and retains the original rotor he can still use the original regulator. I doubt if a rotor for a 63 amp would damage the reg, but I'm not 100% certain about that. I don't think a wiring upgrade is necessary up to 63 amps.
If he wires a 10SI 63 amp, he can run without the #1 wire and use only the #2 and power connected to the output post as shown in Joes pic and it will function like a 1 wire alt. The #1 can be empty. I think this would be the easiest and least expensive. It would also allow him to retain all the original wiring with no cutting in case he should ever want to return to original setup.
Old Jan 27, 2017 | 01:21 PM
  #31
The method I suggested doesn't require cutting either. The field wire from the 12SI plugs in to the old regulator connector with a spade terminal. The sense wire attaches to the threaded post on the horn relay.
Old Jan 27, 2017 | 02:02 PM
  #32
stellar's Avatar
stellar
You lost me Joe. Do you mean connect without a resistor?
Old Jan 27, 2017 | 02:14 PM
  #33
You were suggesting ways to not cut the original harness by not using the field wire. My point is that with a 12SI, the field wire that I showed with the resistor simply plugs into the old regulator connector at the wire that did NOT run to the original alternator (the one that goes to the switched +12V source). Use a male spade terminal on the wire with the resistor and no irreversible mods to the original harness are required. The other two wires go to the junction on the horn relay.
Old Jan 27, 2017 | 03:18 PM
  #34
stellar's Avatar
stellar
got it thanks.
Old Jan 30, 2017 | 12:52 PM
  #35
ReallyWildStuff's Avatar
What would happen if you ran an externally regulated alternator without a regulator?
https://flic.kr/p/QVbgD3
If you can zoom in on the upper left hand corner of this test stand setup (onto the back of the alternator) - the '84 (12SI Alternator) plug didn't fit in the alternator so I had to make a temporary conversion harness...that means its a 10DN alternator, correct? And that means it needs a regulator - right? What happens without one?
I'm sorry all my posts sound like "Why is there air?" or whatever but...I got this alternator from a friend just to test. It didn't even occur to me that it could be externally regulated.
I had the voltmeter on the system when I had it running and it seemed to put out 14.4 nuts on the whole time...
Old Jan 30, 2017 | 02:16 PM
  #36
That is a 12si alternator. It is internally regulated. It does not need a regulator.
Old Jan 30, 2017 | 03:33 PM
  #37
Thanks. The pinout on the spade terminals ("1" & "2") does appear to match that of a 12SI.
What to make of the fact that the white/red molded plug doesn't physically fit into the reliefs in the top of the case housing? Perhaps I have a a "10 SI" - internally regulated, but the plug is of a different configuration?
http://alternatorkit.com/alternators.html
The vent holes on mine match the 2nd 10SI image in the link above.
For comparison - I see that on the 10DN the connections are made from the back (not the top) and are labeled "R" & "F". Also that the back of the 10DN case is markedly different from the SI series.
Old Jan 30, 2017 | 03:38 PM
  #38
The 12SI is just a newer, higher output version of the 10SI. They are functionally, dimensionally, and electrically interchangeable (allowing for amperage differences). Both are internal regulator designs.
Old Jan 30, 2017 | 03:44 PM
  #39
The alternator in the photograph is a 12si.
I don't know what setup you may have on your car, but we could tell you more if you could post a few more pictures (and actual pictures are better than Flickr links, as it is tough to find the actual url of the photo within the page's code).
Old Jan 30, 2017 | 03:46 PM
  #40
I will get better photos tonight. I obviously don't _know_ (that's why I'm here) but I would still like to find out why the plug won't fit.
