Adding gauges and electric choke to 71 Cutlass
I’m adding a Sun Pro 2 tach and electric choke and oil,water, and volt Sun gauges. What’s the best way to get power to all of these at the fuse box? How have you guys done it?
There will be a couple power taps on the fuse box labeled ignition, another labeled batt (short for battery) and another labeled lamps. Other than the tach connection under hood, that should be all you need
i believe there is a sticky on choke wiring.
76CutlassSalon
February 20th, 2016 06:38 AM
