Adding gauges and electric choke to 71 Cutlass
Old Aug 7, 2019 | 09:33 AM
rktolds's Avatar
I’m adding a Sun Pro 2 tach and electric choke and oil,water, and volt Sun gauges. What’s the best way to get power to all of these at the fuse box? How have you guys done it?
Old Aug 7, 2019 | 11:20 AM
There will be a couple power taps on the fuse box labeled ignition, another labeled batt (short for battery) and another labeled lamps. Other than the tach connection under hood, that should be all you need
i believe there is a sticky on choke wiring.
Old Aug 7, 2019 | 11:24 AM
rktolds's Avatar
Thanks. Didn’t know if I could use the bat spade or just the IGN. I didn’t see a lamps spade but will look again.
Matt
Chuck Cole
Jul 9, 2019 09:38 PM
76CutlassSalon
Feb 20, 2016 06:38 AM
ELECMAN
Jun 22, 2010 05:30 PM
dallasite21
Jan 21, 2010 08:32 AM
mp71conv
Jan 21, 2009 02:28 PM
