Electric Choke wiring
Since almost everyone recommended a 7111 intake and an electric choke on the carb, that is what I bought. 6 weeks of waiting from Jegs and I-5 and now my engine is complete. Can someone give me a quick and dirty on the choke circuit? There were no instructions and no wires, and no gasket. I am assuming this is pretty straight forward, but I don't know whether the choke works on heat or a switch, solenoid or what? When I am asking these questions you must realize I am nearly finished with a nightmare of an engine swap! There are some things that appear usable from Buick to Olds, like the pulleys and P steering bracket... Oh to be a welder!!!
The electric choke has a heating element that needs to be connected to a 12 Volt source that is active when the ignition is turned on. The element grounds through the carb body, so DO NOT use a gasket between the choke and the carb. I wired the choke to the IGN terminal on the fuse block as that's about as simple as you can get. Joe P has posted how to wire it through an oil pressure switch so that the choke is powered only when the engine is running, which is a very good idea.
